What have you done / plan to do to your Telly?
I got EX with bench seat. Thinking of changing LED lights. Any model recommendation to change LED lights? This seem to be the common mod here.
I have had good luck with my top of the line LASFit LED headlights.
For EX trim with bench seat , what are the easiest lights to change. Based on reading here, I can change front main, turn signal and rear license plates? Are we good with switching front lights for long drives (6-7 hours). Current halogen lights, seem to light up fine except color of the light is very yellow.
I have had no issues with the LED headlights over long durations. I have NOT found a replacement front turn bulb that does not hyperblink, although it hasn't been for lack of trying. I do not know what rear lights the non-premium EX has, but on my S I replaced the reverse lights and highly recommend doing so if you have halogens there too. I bought the LASfit ones and love them, they also look good in the housing.
I have replaced all bulbs in the rear tail light housing with LEDs as well to make them brighter: tail, and brake. For a while I had LED rear turn signal bulbs too but they randomly tripped error codes on my dash so I have given up on rear turn LEDs.
Thanks for the information. Amazon says Lasfit 9005 doesn't fit 2022 Telluride. I am assuming, it is the case of not up to date information. I can go ahead and buy these right? i will stick to factory front and rear turn signal lights for time being. They are used on demand anyway.
I have a EX. I should have LED light house and break light. I need to replace name plate lights with LED for the rear right?
What is difference between these 2 listings,
Pretty sure they are the same bulbs in those listings. I had the 60W at first but decided to upgrade to the 72W bulb and it is definitely a better bulb, more even road coverage. I would check the LASfit website to see about fit. The reverse lights I definitely recommend upgrading, such better reversing visibility. The license plate lights could be swapped too but that is purely an aesthetic choice to keep the colors at the rear of your telly all white instead of the yellow-ish hue of halogens.
Deleted.
Ceramic tint, new shoes, and an extra 2”!!
Which ceramic tint (CTX ceramic vs IRX/Nano) you went with. How much is for 1st row, 2nd row and 3rd row seats? 2nd and 3rd windows are already shaded. How much is the factory shade? I am planning to get it tinted my car this weekend.
When Tint % is mentioned, it is amount of light transmitted into car right?
Any one applied tint to sunroof. I have one sunroof. Not sure if it is laminated vs tempered. Shop recommended against applying tint to sunroof. As we have slider door covering sunroof, do we need tint?
I believe it was @Bohen that made the point if the window gets busted, tint will help keep it together. I agree. Depending on where you live as well I guess.
Duplicate post.
Hi,
I have replaced with 60W bulb. They are not bright. Other cars (Tasla and Corolla)with LED lights are much brighter. Does upgrading to 72W makes it brighter?. Is it safe to install 72W ones in 2022 EX?
Do we get tempered sunroof in EX? Recommendation is not to tint if it is laminated.
How bad is the flickering with the LasFit led headlight bulbs with the auto stop/start? Does anyone have a video?
It is just one quick flickr but noticeable if one pays attention.
I can confirm with ritholtz. The flicker is barely noticeable from the driver unless many reflections may be present. Never been head on with my ride to see what it would look like to oncoming traffic but I presume they would notice a flicker as well.
My experience is that the flicker is noticeable enough that people frequently think I’m flashing them. I bought these: “LASFIT 9005 HB3 LED Bulbs 60W 6000LM 6000K White Adjustable Beam” in March 2021. The lights are still going strong, but I do wish they didn’t flash with the auto start, enough so that I often turn off the auto stop/ start at night.
I added weathertech floor mats
"Stop Drop" inserts
Rain guards
Window tint
Ambient floor lights for the 1st and 2nd row
Cargo basket
Cargo cover
US Navy license plate cover
USB cables with multiple connections for 2nd row passengers
Also bought the hand made leather fob holder(from the same place)
I've just added a clear bra and ceramic coating
