Trying to install the ISG module. Pin 3 on F52 is NOT 12v acc, pin 1 is, it's a red wire. Pin 24 on F51 is GND, black wire. Not sure about the others, don't want to continue and fry something. @Lith_SXPN is this pinout for the Telluride or some other vehicle?If anyone is looking to install the ISG/Auto Hold module, here are the pin outs. The module is untested(by me) and pin out does not guarantee the module will work.
Location of the connectors. You need F51, and F52
F51 Connector
Pin 4 - Auto Hold
Pin 8 - ISG Switch Signal
Pin 10 - ISG Switch Indicator (Not used for resistor mod or EZLED Module)
Pin 24 - Ground
F52 Connector
Pin 3 - 12v Acc
Too late to get in on this?
Those pinouts are from Telluride service manual. Often times, the pin numbers are marked looking from the front of the plug(opposite wire side). Can you take a picture of the plug?Trying to install the ISG module. Pin 3 on F52 is NOT 12v acc, pin 1 is, it's a red wire. Pin 24 on F51 is GND, black wire. Not sure about the others, don't want to continue and fry something. @Lith_SXPN is this pinout for the Telluride or some other vehicle?
That was my first thought, except pin 4 on F51, looking from the back, would be empty. I'll take a picture in the morning.Those pinouts are from Telluride service manual. Often times, the pin numbers are marked looking from the front of the plug(opposite wire side). Can you take a picture of the plug?
Edited my post above to include the SM pinouts.That was my first thought, except pin 4 on F51, looking from the back, would be empty. I'll take a picture in the morning.
Okay, images of F51 & F52 attached.Edited my post above to include the SM pinouts.
It doesn't require constant(continuous) 12v. Acc(switched) is all you need if I recall from my Stinger ISG installation(same module).Okay, images of F51 & F52 attached.
Looking from the back the pins are labeled from left to right.
The drawings that are above are viewed from the front of the connector.
Connector F52 pin 1 (red) - 12v continuous
pin 3 (brown/black) - 12v switched
I just need to see if the module needs switched 12v and will remember last setting or I'll have to use continuous 12v.
I think @rwhite4573 printed out the same instruction as the first post of this thread. Just compare your printed version with 1st post. If it's not the same, go with 1st post.Hello Telly friends just got home from vacation & my module came...should I just follow the instructions sheet that came with it??
Okay, connected everything up as follows:It doesn't require constant(continuous) 12v. Acc(switched) is all you need if I recall from my Stinger ISG installation(same module).
If you're installing the proximity door lock/unlock it's easy if you just follow the instructions from Lith_SXPN. He put together the PDF you can find at the link below.At the risk of sounding dumb, The more I read all these installs the more confused I am getting. Someone Pls do a video.![]()
I also sent a color copy of the door proximity instructions attached above with the door proximity modules I shipped.If you're installing the proximity door lock/unlock it's easy if you just follow the instructions from Lith_SXPN. He put together the PDF you can find at the link below.
Glad to hear everything worked out!For ISG/Auto Hold Module install
Everything is working correctly as connected as follows:
ISG Module Accessory Jack
red/yellow 12v --- red wire - 12v switched
black - gnd --- black wire - gnd
ISG Module Wire Harness
green - auto hold --- F51 pin 4 - blue/red - auto hold switch -----> NOTE: this is L/O in the above pinout diagram
orange - isg --- F51 pin 8 - orange/white - isg switch
I attached the ISG/AutoHold module on the wall to the wireless charging pad with double faced tape.
I went with the accessory jack for power because F52 was not providing enough current(module wouldn't power on).
The pictures below show which state the leds will be in depending on engine on/off or accessory mode.
note: when switching to accessory mode all three leds will light and then the bottom two in the picture will turn off.
