Map Update v16.0 Arriving May 5th
Hmm, I would think as long as you have an active subscription and a good data connection, you should be set.
I used a 64gb USB, and it took 1 hour 25 minutes. The first half of the download took the bulk of the time. Then, about 20-25 min to finish.
All the above here too!!
Accessory mode worked for me.
The update strangelY changed the units of distance from kilometers to miles ( I am in Canada).
Page 4-86 of the 2022 Manual says that there is an option for “speed unit” under “user settings” - “other” but I don’t see it ( see photo)
Anyone else in Canada update the maps/infotainment and have this problem ?
Loving the new XM interface. I also love the widescreen Android Auto. However, I wish the car would automatically switch back and forth between spilt and non spilt depending on whether you are listening to an Android Auto source or Radio. That would be the icing on the cake.
This has happened intermittently to some in the past.
Setup > navigation > guidance > detailed guidance > units
So I installed the new update (took an hour and 15 min...) I have split screen enabled on android auto, but I am not able to get the "full" screen experience that other users have received. On the last third of the screen I only get the android auto logo OR the Kia interface (maps, weather, etc.)...is there something else I need to enable to get the full screen experience? I know the update worked, because I verified the software version and the radio now thankfully has the list instead of the vacuum tubes...any insight would be helpful!
You have to disable the split screen so that Android Auto can take the entire screen.
Got it, I thought I had read somewhere else that it had to be enabled. Thanks for clarifying!
I guess I'm going to have to take the plunge. Please remind me, do you have to have the car idling the whole time or will it work in Accessories mode?
It sounds like it’ll work in Accessories mode based on some other posts here. I’m gonna try it instead of having the car idle for the hour+ that this one seems to take.
I stil have not been paying for UVO subscription for over a year and my weather still works after updating to v16.0.
I updated on accessory mode using a battery charger. Took about 2 hours. My system was running the April 2021 version. There was a point after the first hour where the screen looked like it was completely off.
Other observations after updating:
  1. The route guidance makes the streets look wider on the map now with white arrows to distinguish it from other streets on the map. Previously it used to be hard to distinguish the route unless there was colored traffic data.
  2. When trying to start the UVO route guidance with Apple carplay running, it gives an error about requiring a subscription. After disconnecting Carplay it works fine. Did not used to do this for me.
  3. Updating removed all my saved places again for UVO navigation.
Overall, nice to be able to custom order the presets and have the latest map data.
Currently having the same issue, can you specifically run through where you enabled this to work on full screen
Figured it out, need to not be on AA to get to that screen. All good
I use a carsfi wireless Android puck. It worked fine until this update but now I get this message. It works fine when I run it wired. Anyone else ever seen this?
Where is the setting? I can't figure it out.
Installed the update. Everything seems to be working correctly but I noticed something different I think. I asked to find directions for a certain address. The navigation kept asking me to choose which POI I was looking for. I was looking for a home address. If I asked it to find this address, then it would find the correct address. Is this a change. Thanks in advance.
Well I don’t recommend putting the car in Accessories and doing the update. After running for about an hour the car turned itself off. Now the head unit stays black and doesn’t then on. Probably will have to take it to the dealer. So much for trying to save gas. My mistake.
