md2463
- Jan 15, 2023
Would the 10mm hex socket fit for the front fill plug? Or what size did you used to open that?Finally got around to try loosening the top fill plug!! I call it plug (versus bolt) because it’s made of plastic! This is very important before anything else—that is, before draining the fluid to make sure I can refill it. You can also use the front fill bolt/plug if you have a pump (available at walmart auto aisle). I found an old 10mm hex socket (less than $10 at Harbor Freight) and used a six inch (longer is better) sparkplug socket extender to reach the fill plug (see attached pictures). It is very tight to use a wrench in there (what did you use?). At any rate, I plan to change the tranny fluid before this summer. By then, my Telluride will be at around 22-24k miles. If I can change the fluid every 20k miles I will have changed it (drain and fill) three times by the time it reaches 60-70k miles (severe msintenance schedule)! I will be using Kia’s ATF SP4M1 (not sure yet if this is compatible with 2021 Telluride but I will inquire about this). Thanks!
