Is anyone here having the driver settings reset issue?
I just encountered this this morning on my 2020 SX Prestige. No idea why it happened. Very annoying. I'd like to know the cause as there seems to be no reason why it happened and I have no reason to think it won't happen again.
It happened this morning on my 2024 telluride. Very annoyed as everything has to be set up again. And my navigation history is also gone.
Just happened on my 2024 telluride this morning as well. Maybe they pushed an OTA update?
Ha, same here. Did kia push out an update that borked it all up?
Just happened to my 2024 Telluride too!
Happened to me this AM in my 2023 Telluride. The secondary driver profile is there but the primary one is gone and the time settings have changed.
It happened to me on my 2020 SX Prestige earlier this morning. I am going to do the latest software update from the Kia website today and see if that helps as I can't change the radio stations to FM, AM, as it just stays on SiriusXM on the preview channel 1. Will let you know how it goes.
Must be a system issue. Happened to me this morning. Got a pop up mentioning something about my connected phone and resetting user profile. Then everything was wiped. I reset it all up. Then it happened again 30 minutes later.
Same thing. Got in this morning, something about First something popped up, and all my setting were gone. Had to redo everything. Huge pita.
Same situation with my 2024 Telluride. Secondary driver profile remained. All setting related to the primary profile are gone.
Same thing happened this morning with my 2022 Telluride.
Wonder if I should set up both profiles with the same info in case this happens again. Frustrating. But I guess this wouldn't help with losing with the navigation history.
Happened to me as well this morning. 2024 Telluride SX.
Everything is gone from the settings. Back to factory default. How did this happen?
