2025 Telluride - CarPlay stopped working
jajaxxon47
2025 Telluride s-xline prestige - 5 weeks old
CarPlay was working both with a cable and separately with a wireless (both Carlinkit and Ottocast) adapter
Today it just stopped connecting using any method - multiple cables and both adapters - nothing works
Phone charges, so I know the USB has power
CarPlay is enabled thru the phone projection setting on the screen - turned it off and them on again - no effect
Restarted phone (16 pro max) and still nothing
Any suggestions on things to try to regain CarPlay access?
Thanks
I would try the following:
Screen reset: Press the start button twice and using the tip of a pen, or a paperclip, press the reset button (tiny button between the volume control and the map button) for five seconds. You may lose some customization settings and need to reset them.
Remove negative battery cable for 30 minutes or overnight: You may also lose customization settings and need to reset the auto up/down on window controls.
Be sure you are connecting the cable via the USB-A connector on the console. I'm guessing you already know that. Note that I had to try two or three different cables to get one that worked.
Thanks for the suggestions
1 wk old telluride newby same issue CarPlay should auto load just like my other cars, as soon as i plug in my iPhone 13 to my jeep and dodge it pops right up.
so i swip left to show list of icons "phone projection" comes up but not carplay
one thing i found while on a long drive if the usb cable touches the screen it turns off
getting CarPlay hit or miss
i've tried your options and yes they work, but shouldn't have to
any settings that just let it "auto load"
2025 sx P does it have wireless CarPlay??
thank you for your help
Thanks
Thanks for your post. My wife and i have had only frustrations trying to get the stars aligned to make calls and to use apple play. We tried the bluetooth attachment to make life easier but when we both have our iPhone's in the car who knows whats going on. Just too many variables and honestly it is the most concerning problem with the 2024 telluride. I really hope a software upgrade by Kia could help us all out.
The only USB port that works with CarPlay is the left USB-A connection in the console. I've found it to be very "cable sensitive" and not all USB-A to USB-C cables work. The one that works best for me is the Belkin one. When I use a good cable mine works every time.
Native Wireless CarPlay is not an available option due to the licensing agreement with the company that supplies the Telluride navigation system. I've purchased an aftermarket one that works great - it is the CarlinKit 5.0 Wireless CarPlay/Android Auto Adapter USB for Factory Wired Cars (Model Year: 2015 to 2025).
Note that none of the 3rd party wireless CarPlay adapters allow you to connect multiple iPhones at the same time. I personally think it is a good thing as if the other person is actively using their phone while in the car, it will keep switching screens to their content. It would drive you insane.
Good news is that the 2027 Telluride will have native Wireless CarPlay.
Hear/Hear
BTDT, it IS insane. Don't go there.
Sidebar: My wife's Toyota Crown will pair with both of our phones (two of us in the car) simmoutainousely. Then she touches the wrong thing, car play kicks on/off, hers/mine etc. I'd prefer if it would only sync with one at a time.
Furthermore. I'm in the house on a call. She's leaving the house and starts her car to drive away. The damn Crown will snatch the call right out of my hands until she is a block away, leaving me with a seemingly dropped call. Arghhhh.
Hear/Hear
Same issue. I have a wireless dongle and that happens when my wife leaves and when she returns to the garage. I can't see way around it other than using a wired connection.
