I will continue to provide updates to the thread as any information is received, but I have little confidence that an actual solution will be identified.
Any update...?
Excerpts from the manual (didn't copy the multitude of warning messages):
- The Forward Collision-Avoidance Assist (FCA) is designed to detect and monitor a vehicle ahead or detect a pedestrian or cyclists in the roadway through radar signals and camera recognition to warn the driver that a collision is imminent, and if necessary, apply emergency braking.
- The warning light illuminates on the LCD display, when you cancel the FCA. The driver can monitor the FCA ON/OFF status on the LCD display. Also, the warning light illuminates when the Electronic Stability Control (ESC) is turned off (Traction & Stability control disabled.). When the warning light remains ON with the FCA activated, take your vehicle to an authorized Kia dealer and have the system checked.
- The FCA system will operate if the vehicle speed is greater than 5 mph (8 km/h) and less than or equal to 100 mph...
----- For pedestrians and cyclists to be detected, the vehicle speed must be greater than or equal to 5 mph (8 km/h) and less than 55 mph...
- Additionally, some vehicle system intervention occurs by the engine management system to help decelerate the vehicle.
- The brake control is maximized just before a collision, reducing impact when it strikes a forward vehicle.
---- The FCA system will operate if the vehicle speed is greater than 5 mph (8 km/h) and less than or equal to 50 mph (80 km/h) on a forward vehicle.
---- For pedestrians and cyclists to be detected, the vehicle speed must be greater than or equal to 5 mph (8 km/h) and less than 45 mph...
So it appears there are several maximum speed levels, depending on what situation is being referred to:
- for warning about a collision with:
---- another vehicle, 100
---- a ped/cycle, 55
- for brake assist to avoid a collision with:
---- another vehicle, 50
---- a ped/cycle, 45
And, all of this is if the radar sensor area is not covered with snow or dirt to disrupt the radar.
Anybody else confused...????
I've had the FCA warning and chime pop up, and the engine slow up, a couple of times when someone was turning out of my lane and I got a little closer than the system liked; but, have not had the brakes engage.
Driving in snow for the first time today - had the "Forward Collision-Avoidance Assist (FCA) system disabled. Radar blocked" warning pop up, which disables the Smart Cruise Control that was in use at the time and popped a couple of yellow 'idiot' lights on the dash... that was interesting... you think they would have put a heating element of some sort to keep the sensor cover from collecting snow...
I hope they have either solved your issue or replaced your vehicle; and compensated you for your inconvenience...
