Ambient Light for $9.45?
Great job. If you want to have the wire completely hidden just install one of these. Would be a pretty simple install to the fuse box if you use an "fuse tap"
That is a fantastic idea!! Thanks for the link!!
You are welcome. Make sure you verify the fuse size before you order the tap. Not sure if the Telluride has full size auto fuses or the smaller ones.
I have used the cheap China USB adapters on motorcycles for the last five years and they work great. I've yet to use a fuse tap but I have a bunch I bought a few years ago. They look to be well made and should work just fine.
Could this be integrated into the headlight switch so that when the headlights turn on, these do as well?
