Eleven USB connectors, Ten ports for charging only. And the one port that accepts data connections will not accept a hub.
I found a way to connect 2 devices, switching between them with a touch of a button. I got a "printer sharing switch".
It is not a hub, but a switch. Widely available, Sabrent USB-SW30. I got mine at Amazon ($15):
https://www.amazon.com/gp/product/B074TYDJK2/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
A drawback is the two connectors for the USB devices are clunky Type B. For most things you will need to
hunt up an appropriate cable or an adapter. I'm using adapters to go from the Type B to a female Type A.
My use case is a music thumb drive in in port, my Android phone in the other.
Don't use it often, but Android Auto works through the switch.
HTH someone, Jon
HTH someone, Jon
