Headlight Led Upgrade
I wanted to follow up with my experience on the Sealight series 3 LED replacement lamps. I'm about 2 years in, and one of the lamps has "soft-failed" - by that I mean I get a "check headlight" notice in the instrument cluster display but the headlamp still puts out light. I can't say for sure, but it appears to be dimmer than the other lamp (maybe 1/2 output).
I'm going to read through the recent posts and see if there is a consensus on what the best option is 2 years on. Hopefully things have improved and there is a clear choice, but maybe I will end up with some other non-LED alternative.
Mine just started that this weekend. I have the Auxito LED headlamps with about 13 months and 18k miles on them. To be sure it wasn't anything else, I switched the headlamp to the other side, and my dash notification pinged the side I moved it to. I also believe the one that is triggering the notification to be dimmer.
Did you find a solution? I may just end up ordering another set, and keeping the 'good' one as a spare.
Call the shop at +19049559844 and talk to Chelsea. I specifically asked if they could ship to memeber and they said they would. The bulbs they use are custom manufactured for their shop. The ones I got were 6000k and are bright as hell.
Twelvolt has unfortunately gone out of business.
Same exact thing happened to one of my 1 year old auxito lamps last week, car starts alerting relentlessly that a bulb is out, I mean it beeps forever until you change it,lol. The one it indicated was dead still produced light but it was much less than the other. Ordered another pair as I have been very happy with the light output and pattern and they don't cost a fortune, a one year life span however is not so great.
This is the most accurate description for anything ever. Hahahaha
Agree with you completely, and just ordered a replacement set. Glad to know i wasn't alone with this. Thanks.
