asgalang
Mine just started that this weekend. I have the Auxito LED headlamps with about 13 months and 18k miles on them. To be sure it wasn't anything else, I switched the headlamp to the other side, and my dash notification pinged the side I moved it to. I also believe the one that is triggering the notification to be dimmer.I wanted to follow up with my experience on the Sealight series 3 LED replacement lamps. I'm about 2 years in, and one of the lamps has "soft-failed" - by that I mean I get a "check headlight" notice in the instrument cluster display but the headlamp still puts out light. I can't say for sure, but it appears to be dimmer than the other lamp (maybe 1/2 output).
I'm going to read through the recent posts and see if there is a consensus on what the best option is 2 years on. Hopefully things have improved and there is a clear choice, but maybe I will end up with some other non-LED alternative.
Did you find a solution? I may just end up ordering another set, and keeping the 'good' one as a spare.
