The instructions and Notices are in English and French only in my kit maybe they are translating to Spanish for USi still dont understand why you cant get these in the US?? so stupid..
Which model/trim telluride does this fit?
This is for 2023 and up Palisade and Telluride and as far as I know all Tellurides have the plug in the jack storage area to hook up the Wire Harness, It really is easy enough to pop off the jack storage cover and remove jack and tools and see if you have the white connector that is taped to a larger wire harness on the drivers side.Which model/trim telluride does this fit?
Yes that is confirmed by another member who managed to get the harness in November 2022 for his 2023 before it went back order. I will definitely update when trailer is hooked up, but already all the lights work as mentioned earlier.This is amazing - to confirm, this part can be used to install a 7-pin on a 23 Telluride by plugging into the port near the jack? Let us know when you have your trailer hooked up that all is working. I was just about to install aftermarket but will wait if this is a workable solution.
Thanks for your detailed posts, pics etc. I’m waiting on my harness, they say a week or so and mine should ship. When you hook your trailer up can you let us know if the backup warnings and autonomous braking are automatically disabled when you shift into reverse with a trailer attached?Yes that is confirmed by another member who managed to get the harness in November 2022 for his 2023 before it went back order. I will definitely update when trailer is hooked up, but already all the lights work as mentioned earlier.
Just removed my direct wire Curt Tail light converter 4 pin and 4 to 7 PIN adapter Kit. Good news is that after inspecting the factory wire after removing the wire tap, no strands of wire are damaged on the factory tail light wire harness that I can see with a magnifying glass.. Just goint to put a piece of electrical tape over the tap area and put the tail light back in.
You will on a 2024 I bet. Then when they have a healthy parts supply they will have an official Telluride version for the 2023 on order. Then the third priority will be stocking parts departments for 2023 owners. Remember, worldwide Hyundai makes more Palisade than Kia makes Tellurides. By the time Kia has an official part for the Telluride, Curt or Tekonsha may have their own plug in version.i still dont understand why you cant get these in the US?? so stupid..
Is there anywhere to purchase these harnesses now? I know most have been waiting on these orders for months.
Look at post #19 of this thread and see if you have the white plug that has nothing connected where the tire jack sits:Do you know if this is only for units with tow pkg.from the factory???I have a S with no tow pkg.wondering if it would work on my S??? Thanks for all this info very very helpful!!! I have installed etrailer hitch....
Came here to say this. I think I’ll order one from Etrailer and HOPE that it gets here by the 18th. It’s estimating the 16th as of now. I leave for vacation with a 4 pin trailer on the 18th… if not I guess I’m splicing.For those of us that don't have/use a 7 pin and don't have the tow package Curt has a plug and play harness coming out in 1-2 weeks according to the email I just received from a customer rep. The part is Curt 56490 and is going to be available at the usual retailers. I can't post the link to the part, but go to Curt's site and put in your make/model... it'll show up. Plugs into the tail lights with a battery wire. Better than splicing into wires for me and is a 4 pin flat. Also works for me.![]()
