Other than allowing you to have an always black map mode, this is probably the most noticeable change with the update – they moved around most of the items on the home screen and removed the driver profile selector from this home screen as well.
One thing to watch out for... the update deselected both "Enable
Android Auto" and "Enable
Apple CarPlay" in their respective settings. So if you are trying to plug in your phone to use either of those (or using a wireless adapter), you might want to make sure the settings are re-enabled before you waste time wondering why your device won't connect.
Also, because I know there will be questions...
NO, this update does NOT bring full-screen Android Auto capability. Yet another update without enabling it (this is the fifth one now since Google enabled it)... it's not going to happen, people.
