You may not be the only one, but you’re definitely in the minority, at least based on this forum and other Hyundai/Kia forums and online groups.Am I the only one that likes the radio tubes?
That's funny, I think the new radio interface is boring. At least the tubes gave it some character, I never minded them. Though I was a fan of the triple split screen. But the car is great, we are all spoiled.Am I the only one that likes the radio tubes?
I thought this too when I looked at the screen from outside the car, so I went to check on the progress. When I pressed the start button to get back to accessory mode it went immediately to the “Installing Maps 1/5” screen. I let it do it’s thing for another hour and it was finished.After running for about an hour the car turned itself off.
I'm excited that the 2 things I missed most are back! I can reorder the stations AND I can see what's on the radio while having a map up that shows speed limits. To get this screen, I pushed the radio button and then the tiny arrow on the far right.
Looks like they pulled the update late yesterday for newer systems. The only updates that are still up currently are the ones for older gen 4 navigation systems.I’ve tried to download the update this morning but it says Download for this vehicle is not yet available? 2022 Telluride…![]()
Whaaa..interesting. Well, thanks!Looks like they pulled the update late yesterday for newer systems. The only updates that are still up currently are the ones for older gen 4 navigation systems.
I had the same thing this morning when I went to try. I did the guest login mode and it worked. THEN I saw that they pulled the update. -_- frustrating.Is anyone having issues with the Navigation Updater? It will not let me log in, says System Error. I tried uninstalling and reinstalling but same thing.
Ah, I see that now, but the Guest thing did work. Well here's hoping it's working by tonight!I had the same thing this morning when I went to try. I did the guest login mode and it worked. THEN I saw that they pulled the update. -_- frustrating.
Wow! Thanks for that info! I didn't realize I could scroll up and down and get the compass, clock, weather, etc! That's cool!FYI...if the map is not showing by default on that side, swipe up/down to get to that view.
And if its still not there, check your settings to enable those items you can view from split screen.
