I think they'll look pretty good, no matter the color of the Telluride.
Thoughts on these with gravity grey? Love the price point and the machined color.
- Offset: 32mm
Can I ask if this is Everlasting Silver or Gravity Grey?this past weekend, i did a test fit of my old Axis Model 5 and they fit perfectly. the specs are 19 x 8.5, 114.3 bolt pattern, 35 offset. i am still deciding if i wanna use this wheel set or get new ones. decisions, decisions, decisions. LOL!View attachment 370
I think those are too aggressive fitment for Telluride. Perhaps the 22x9 with +32 might work on rear but then, it will be slightly poked out if you mount those on front.Asanti abl11. They make 22x9 with a +32 offset and 22x10.5 with +35. I know for a fact that the 22x9 fit with 265/40 tire, but they dont have that concave look im after. Thats why i was asking if anyone had tried 10.5 with 285/35 tires.
Looks great! Can you share the size of wheels and tires? Thank you in advanceA coupe days shots with the wheels.
Wow, great finding, those are 45 percent off! Based off my research via forums, looking at the pictures with wheel specification infos provided. Rear would be okay but the front can poke out little bit. I think the perfect fitment for front is; (diameter)x8 30-32+ET or (diameter)x8.5 37-40+ ET. The wheel you are looking at is 9.5 40+ ET. Try using this site: https://www.willtheyfit.com/I'm thinking of getting these 21" wheels at Tire Rack which are listed for the Telluride and also a great closeout price. The offset is close to oem too.
Would the 9.5 width be an issue? Tire Rack suggests a 265/40 tire for it. https://www.tirerack.com/wheels/WheelCloseUpServlet?autoMake=Kia&autoModel=Telluride+AWD&autoYear=2020&autoModClar=S&target=runWheelSearch&wheelMake=Quad&wheelModel=Hamburg&wheelFinish=Machined+w/Light+Grey+Accent
You can also try this which may help explain the relationship between offset and widthThanks so much Eragon. I hadn't seen that site willtheyfit.com before, very helpful. I'm not worried about the 18mm to the outside but the
32mm to the inside sounds like a lot. I'll just trust that TireRack wouldn't put on there for the Telluride if it's problematic with the struts.
I love how those look, great choice.View attachment 6341
Sorry I went MIA for a bit... attached are the pictures with the wheels installed. 20x9 +32. 255/50/20 tire. Love the way they look and they have minimal poke. I appreciate everyone's responses to my initial post.
Wheels look great. I just ordered my Telluride as well in Southern Ontario. What dealership did you order the wheels thru?Finally got my Braelin BR10 installed. I'm actually loving the look. They aren't black so i was nervous but i think it turned out pretty good!View attachment 4517View attachment 4518View attachment 4519
Black Rhino Mozambique
Rotary-Forged 20x8.5, ET35 Satin Black
