Thoughts on these with gravity grey? Love the price point and the machined color.
  • Offset: 32mm
I think they'll look pretty good, no matter the color of the Telluride.
  • Like
Reactions: SAB
Thanks, I agree. Just wanted to get some other opinions. I think the multiple-spoke black wheels are way overplayed on Tellurides. Just want to be a little different.
  • Offset: 32mm
I think they look good. Pretty chunky/strong style which fits the Telluride well. 32ET with a 9" is fairly aggressive offset wise, looking forward to see how they look. Not sure I've seen anyone on here with that offset on a 9".
this past weekend, i did a test fit of my old Axis Model 5 and they fit perfectly. the specs are 19 x 8.5, 114.3 bolt pattern, 35 offset. i am still deciding if i wanna use this wheel set or get new ones. decisions, decisions, decisions. LOL!View attachment 370
Can I ask if this is Everlasting Silver or Gravity Grey?
Asanti abl11. They make 22x9 with a +32 offset and 22x10.5 with +35. I know for a fact that the 22x9 fit with 265/40 tire, but they dont have that concave look im after. Thats why i was asking if anyone had tried 10.5 with 285/35 tires.
I think those are too aggressive fitment for Telluride. Perhaps the 22x9 with +32 might work on rear but then, it will be slightly poked out if you mount those on front.
I'm thinking of getting these 21" wheels at Tire Rack which are listed for the Telluride and also a great closeout price. The offset is close to oem too.
Would the 9.5 width be an issue? Tire Rack suggests a 265/40 tire for it. https://www.tirerack.com/wheels/WheelCloseUpServlet?autoMake=Kia&autoModel=Telluride+AWD&autoYear=2020&autoModClar=S&target=runWheelSearch&wheelMake=Quad&wheelModel=Hamburg&wheelFinish=Machined+w/Light+Grey+Accent
Wow, great finding, those are 45 percent off! Based off my research via forums, looking at the pictures with wheel specification infos provided. Rear would be okay but the front can poke out little bit. I think the perfect fitment for front is; (diameter)x8 30-32+ET or (diameter)x8.5 37-40+ ET. The wheel you are looking at is 9.5 40+ ET. Try using this site: https://www.willtheyfit.com/
It generally tells you how much it will poke out but you must measure with measurement tape from wheel to the wheel fender to know how much of space you have. I like wheels to be flushed with wheel fender or slightly in.
Thanks so much Eragon. I hadn't seen that site willtheyfit.com before, very helpful. I'm not worried about the 18mm to the outside but the
32mm to the inside sounds like a lot. I'll just trust that TireRack wouldn't put on there for the Telluride if it's problematic with the struts.
You can also try this which may help explain the relationship between offset and width
Sorry I went MIA for a bit... attached are the pictures with the wheels installed. 20x9 +32. 255/50/20 tire. Love the way they look and they have minimal poke. I appreciate everyone's responses to my initial post.
I love how those look, great choice.
  • Like
Reactions: SAB
