I'm trying to find out how much it costs after the free subscription runs out. I made an inquiry over the Kia chat line and got no response there.
Hey I agree with all of the above. I went out and got a remote start for my 2020 Telluride from my local vehicle up fitter and it works great. They integrated with the factory remote so no need for two remotes and the climate control system comes on and conditions the car to what ever you had it set at when you last got out. The cost of this was 280.00 plus tax. A much better cheaper alternative than the cost of UVO.
The Accessorides kit does not change the range of your OEM key fob. The range you currently have to lock/unlock will be the same for 3X press remote start.
These numbers are using your OEM fob in general, stock from factory. (ie for locking doors or opening lift gate)
- Does not have to be line of sight if you are about 50 feet away (depending on type of building/obstruction)
- Can work from about 100 feet line of sight
- About 300 feet line of sight if you hold the fob to your chin so your head amplifies the signal.
I may have missed this due to the long thread and I apologize if I did.
Has anyone found out from their dealer if installing the takeover 3x oem start from accessorides voids any warranty on their 2020?
But you loose access in a year and then have to pay for the appYes it has remote thru the app
Actually....the app is free....you just pay for the serviceBut you loose access in a year and then have to pay for the app
Installed the kit from Accessorides. Was $300 for the basic, no override setup.
- Took about 20 min.
- Highly recommend removing the glove box - very easy.
- Wasn't sure where to stash the control unit, so I just shoved it in behind the cables.
- Programming was easy - hard to find the little button.
UVO runs out in a week...was hoping all along the price would come down, but they want $25+ per month and with the LX, I wouldn't even get climate control. Good riddance.
Thank you for this forum and your participation.I was told by my dealer that it was about $5.00 - $6.00 a month. I did add the remote start to my key fob but still waiting on the part to come in. They have to add something to the vehicle.
Thank you for posting this!Uvo app isn’t the greatest. Mine makes me lock the doors from the app, even if I locked them when I get out of the car. So it’s really two steps to start it. You’d think it would know if they are locked or not?
If you have a 2021, all you have to do is press lock on your key, followed immediately by holding the start button for several seconds. That's it.Thank you for this forum and your participation.
Got my Telly last week and am still in the exploring/learning stage. Remote start works via the app on my phone, but does not work with the smart key.
I just called the salesman, and his response was "it worked when you got the car!". Then I was told where the button is, and to press it, apparently thinking I did not know that!
He then said that I need to activate this feature from the car. So far I have not found any reference in the manual pointing to this feature. Maybe that function needs to be enabled????
This forum will no doubt provide more knowledge than the dealership!
Please tell me how to get the part to add to the smart key fob to enable remote start. And can I install it myself?
Thank you in advance!
YES!If you have a 2021, all you have to do is press lock on your key, followed immediately by holding the start button for several seconds. That's it.
Needed to add a great answer I just received:Thank you for this forum and your participation.
To remote start, hit the lock button twice on the key fob. Then press and hold down the start button and the car will start. You can also start it with the UVO app or through Alexa/ Google.Thank you for this forum and your participation.
Thank you for your response; it has been such a relief to receive competent help. And yes, it works very well now!To remote start, hit the lock button twice on the key fob. Then press and hold down the start button and the car will start. You can also start it with the UVO app or through Alexa/ Google.
I have all three options and it works perfectly fine. With the Alexa / Google option don’t rush the process. Two different systems have to talk to each other. It will start, I had no issues..
Just to be clear, you only have to press lock once to get the process started. I've seen this misinformation a lot. It's unnecessary. But if it makes you feel better hitting it twice, you do you.To remote start, hit the lock button twice on the key fob. Then press and hold down the start button and the car will start. You can also start it with the UVO app or through Alexa/ Google.
