CAsuKiHy
So how do we use it efficiently on a 4 way stop. It’s useful on a long light but stop and go not so much?It only saves gas if you make stops lasting more then 10 seconds.
That’s why asked the question. Bmws Volvo’s and others whenever they restart in front of me that thing is loud I’m thinking can’t be good for whatever engine component to do that 100x a day. I like the idea of saving planet and wish could afford Tesla suv but...You'll save $20 a year in gas, just hope that $500 starter lasts 25 years so you break even.
I believe Engineering Explained came to a conclusion of 7 seconds for his particular case. It depends on the vehicle. My RAM 1500 with eTorque saves fuel immediately because it has an electric starter-generator and battery pack to bring the engine up to idle speed, not just restart it using fuel.It only saves gas if you make stops lasting more then 10 seconds.
If you're only going to stop for a split second, then yes, better off preventing the car from shutting off by either applying very light brake pressure, hitting the button to disable autostop, or just letting the car inch forward until you can go again.So how do we use it efficiently on a 4 way stop. It’s useful on a long light but stop and go not so much?
You can disable it, but have to disable it each time you turn the car on. The Stinger forum some people have disabled it permanently by wedging a business card tinto th switch to hold it down. I have just made it part of my start up routine. Start button, ISG off, Auto hold on.
Love it! Does the button have to be pressed in to stay off?So I took a piece of plastic actually the top from a Philadelphia cream cheese container folded it over and wedged it tight between the button. It holds it down and Permanently disable is the auto start stop feature.
YesLove it! Does the button have to be pressed in to stay off?
Auto Start Stop has been around for awhile, I haven’t read (not that it doesn’t exist) significant increase of failing related components for Kia or other brands. The Telluride A.S.S. system is actually much smoother than my previous BMW’s.
