No Hyperflash? They blink normally?
FYI. I upgraded my front bulbs to these Lasfits for a total of 72watts (instead of 60watts) and they're fantastic:
Also, I decided to take the desiccant out (even though they fit with the bulb in...I was worried about having enough room in there for the fan to cool properly.
100% normal, no issues when I bought them at all.
I would also put the back back in the headlight. I had the same headlights before I changed to the SX assembly, but would recommend keeping the packs in there.
Just completed LED upgrades across all the lights on my S Trim and confirmed that it all functions without error codes and hyperflash.
tl;dr
a) LED Bulb Purchased + Cost
b) Ease of Installation
c) Installation Guide
d) My Personal Take
e) Before / After Image
1. Headlamps
View attachment 13006View attachment 13007
2. Front Turn Signal
3. Front Side Marker
4. License Plate
5. Backup / Reverse
6. Tail
7. Brake
8. Rear Marker
9. Rear Turn Signal
Outstanding post, informative, detailed and perfect pictures.
Thanks
Did you experience issues without them?
No, but throughout the forum and just the purpose of them, at seemed better to have them here. I do not think they bulbs will get so hot that taking the packs out will cool them quicker, but that was just my personal opinion of not wanting to remove anything from the assembly itself.
If my headlights get moisture inside, I'll put them back in.
any recommendations on turn signal bulbs for the front as the ones listed are unavailable and according to the YouTube video they say not to buy them as they hyperflash
Thank you for posting, I have had the same issue. When I couldn’t get the bulbs suggested at the beginning of this thread on Amazon, I tried looking at Lasfit but they don’t recommend any for the Telluride (other postings have hinted otherwise but I am not sure which exact bulb works).
Out of desperation I ordered Auxito 1157 amber bulbs on eBay as they advertised no hyper flash. No such luck upon install.
Anyone who has had success upgrading front turn signals to LED, thanks for sharing!
Do the lites on the 22 SX look this good?
These ones I got from Amazon work. I just installed, no hyper flashing or errors on the dash. I kept the turn signal on for 30 seconds without any issue. They are a little bit pricier, but at least they work and you don't have to wait forever to get them from China.
I also had issues with the initial post's recommended Oxilam bulbs for the rear turn signals. I was having hyper flash with them for whatever reason (maybe bad bulbs?). Anyways, these were eventually successful for me:
Will try the front turn signals, thanks for the tip!
These hyperflashed for me
Hey. Sorry to hear that. I’ve had them in since then and have driven everyday since without any issue. No hyperflash or bulb out errors. I have a 22 with led for front and rear turn signals if that makes a difference.
So I got the Lasfit bulbs. To be honest. It looks like crap. Is there a method to installing them. I read about how to position the bulbs inside - 6 and 12 and 3 and 9. Any help would be great. Thanks.DC469CBE-5D5E-493D-B4DA-EE30E522918C.jpeg
I found it weird that after I installed them they would move around to the point they seemed like I did not install them correctly. So I decided to pull them out and the white locking ring stayed inside and out came the LED light bulb by itself. Had to take my time to remove the white locking collard which eventually it came out after I struggled a little. Patience is virtue they say. I was dumb founded played with them a bit and I noticed you have to screw in the white locking ring into the LED light bulb until the white locking collar doesn’t rotate anymore before you try and install them inside the headlight. That way when you do install it the same way the original light bulb came out (quarter turn). It will lock into place and no longer feels loose. Hope it helps others if you still have this issue of them feeling loose.
I found this out also though, of the 2 sets that were sent to me, only 1 of the 4 bulbs worked. I’m sending them all back and regrouping.
The Lastfit bulbs for the lisence plates are way too bright. Maybe because my car is white but it sure doesn’t need to be that bright.
Ordered the LASFIT 9005 HB3 and I attempted to install them on my 2022 lx and they would not fit. Upon further inspection the pin connectors on the led did not match with the stock bulb. The stock bulb connectors seem to have more of a taper. Any one else have this issue. Could it be only with the 22 models?
Yes. I have an EX. I got one of 4 to work. Lasfit sent a second batch since the first batch wasn’t working. I turned them in both directions, on both sides, and still only one ever lit up.
I sent them back. The Lasfit customer service guy feels they are not compatible with the 2022 model.
Wow. I was thinking maybe it was just faulty ones I received but thanks for your reply. So based on your experience, its safe to say these wouldn’t work for the 2022 models?
My experience just doesn’t trust them until I get further information, but this is the quote from Lasfit:
“It seems that our bulbs are not compatible with your 2022 Kia Telluride, please return to the below address:”
If I can keep my patience for 5 months while my car was built, I guess can wait until I find a truly compatible bulb, or Lasfit updates theirs for ‘22 models.
