Aren't all 2020 Telluride's equipped with the Smart Cruise Control w/ Stop and Go (SCC) system? I thought that was standard on the LX and included on ever higher trim.
Personally, I'm not sure how reasonable this is, Kia could have perhaps added a new drive mode for "towing" on the drive mode knob. Perhaps the tow drive mode could just disable the Smart Cruise Control, set the drive mode to something like Smart mode, disabled autostart-stop, disabled the rear parking sensor and turn on the auto-hold. Not even sure if the software/electronics would allow for such a dynamic change.
I avoid cruise control when towing because I want to keep my foot on the gas when towing to make sure I can feel the trailer. Most manufacturers suggest not using cruise control when towing especially if you are going up and down some hills. You could be stressing the transmission by letting it think it's driving without a trailer and working harder with cruise control.
Either way, I'm glad they are fixing this as it could be recipe for disaster if you think your brakes are working and they aren't.
I just took a look at the recall report:
RECALL 20V-436 - 2020 Telluride - Inoperative Trailer Brake Lights
The fix is to install an additional wiring harness . . . could this fix include the same as the 7-pin wiring harness that would supply trailer brake singles to the 12-pin molex connector?
[/QUOTE
