Trailer Hitch
So Palisade has tow package included in top trim, cooling transmission(something that telluride doesn’t have?) and sway control(is that just different wording for auto level suspension), they pore lack proper wiring and claim that can tow 5000lbs which is false and misleading, because you can’t tow 4000+lbs trailer SAFELY!
look at towing on the Palisade. I think it says 1950 towing if i remember what i read
I got the tow hitch installed from the dealership and noticed that the ball was not provided. I have the extension that connects, but not the ball. Again, I have very little experience with towing. Was this the same for anyone else?
If we are all thinking the same, then nobody is thinking.
I am not aware of any dealership/factory option that would include the ball. There are 3 common size hitch balls - 1-7/8", 2" and 2-5/16". Doubtful you would be pulling a trailer with a 2-5/16" ball that is under 5000 lbs. Most hitches under 5000 lbs are now 2", 1-7/8" is becoming less common. It is because of this that the ball is not included, because not all trailers are the same. I have 2 different hitches, that have dual adjustable height balls. Once has a 1-7/8" ball (my Dad still has a couple of trailers with this) and a 2" ball. My other hitch has a 2" and 2-5/16" for my heavier trailers. I only buy Anderson Rapid Hitches now. They are aluminum so they don't rust, can tow up to 10,000 lbs with 1500 lb tongue weight and they can be be used as a drop or raise hitch to accommodate different vehicles and trailer combinations. Link below
You can source just a ball for the hitch that was included. Measure the opening diameter, most hitches balls have a 3/4" or 1" threaded shaft. Purchase the ball size that fits your trailer and the threaded shaft that fits the opening of the hitch. Also keep in mind that your trailer should ideally be level when towed. The hitch you received with your tow package may not level your trailer correctly.
Side Note: It is really tough to type all of this stuff about balls and shafts and not giggle inside a little. :ROFLMAO:
Thanks for sharing. Can't help but to laugh.
Oh quit lying you know the three sizes of balls are too big, too small, and just big enough to catch your fingers between them and the hitch.
I found this on another forum. Don't have time to look at it due to travel plans. But please take a look for those that needed the 7 pin tow adapter.
My S did not come with the tow package, but I did pull off the black cover in the driver side behind the bumper and that 12 pin connector is sitting there. So the good news is that it should be a simple DIY. The frustrating part is when I looked closer there were only 6 wires. So my guess is that pins 1-6 are what goes to the harness and the 7 connects to 1, 8 to 2, 9 to 3, 10 to 4, 11 to 5, and 12 to 6. The 12 pin does not appear to have the reverse lights nor the output for a brake controller to head back to the front of the car.
So wiring the Echo wireless brake controller module still would be just use the 4 pin and run a wire with fuse to the battery or tap another 12v source and a ground. (Leave two disconnected.
To get the full 7 pins for a typical brake controller you would need to run a second wire along with the one to the battery as output to the brake controller and then also find a place to tap into the reverse lights which in the Telluride are in the hatch.
I found this on another forum looking for something else. I was not sure how the owner of the forum felt about me linking another Tully forum. So here is a copy of what I found. I have not had to chance to look at this. But if the wires for the 7 pin that are missing could be tapped from here and run to the rear of the car. Calling out all the DIYers and Tinkerers.
Interior Driver Side Fuse Box
  • MODULE 4 7.5 A ATM (Auto Transmission) Shift Lever Switch, Stop LampSwitch, Driver Door Module
  • AIR BAG 1 15 A SRS (Supplemental Restraint System) Control Module, Passenger Occupant Detection Sensor
  • BRAKE SWITCH 7.5 A IBU (Integrated Body Control Unit), Stop Lamp Switch
  • MODULE 9 15 A Front A/C Control Module, Low DC-DC Converter (Audio), Power Tail Gate Module, Driver IMS Control Module, Driver Door Module, Driver/Passenger Power Outside Mirror,
  • MODULE 12 7.5 A Head-Up Display
  • MODULE 10 10 A Blind-Spot Collision Warning Unit LH/RH, Front A/C Control Module, Rear A/C Control Module, Electro Chromic Mirror, Data Link Connector
  • AIR BAG IND 10 A Front A/C Control Module, Instrument Cluster
  • IBU 1 7.5 A IBU (Integrated Body Control Unit)
  • MODULE 2 7.5 A Surround View Monitor Unit, AC Inverter Outlet, AC Inverter Unit, Front Air Ventilation Seat Control Module, Front Seat Warmer Control Module,2ND Air Ventilation Seat Control Module LH/RH,2ND Seat Warmer Control Module LH/RH
  • MODULE 8 7.5 A Hazard Switch, Rain Sensor, Driver/Passenger Smart Key Outside Handle, Mood Lamp Control Unit, Driver/Passenger Mood Lamp, Driver/Passenger Door Mood Lamp, Rear Dooe Mood Lamp LH/RH
  • S/HEATER (FRT) 20 A Front Air Ventilation Control Module, Front Seat Warmer Control Module
  • AIR BAG 2 15 A SRS (Supplemental Restraint System) Control Module
  • MODULE 5 7.5 A Multifunction Camera Unit, Crash Pad Switch, IBU (Inte- grated Body Control Unit), Smart Cruise Control Radar, ATM (Auto Transmission) Shift Lever Indicator, 4WD ECM (Engine Control Module), Console Switch, Electric Parking Brake Switch
  • IBU 2 15 A IBU (Integrated Body Control Unit)
  • SUNROOF 2 20 A Rear Sunroof Controller
  • MODULE 1 7.5 A IBU (Integrated Body Control Unit)
  • P/WINDOW RH 25 A Passenger Safety Power Window Module, Rear Safety
  • Power Window Module RH
  • RR SEAT (LH) 25 A 2ND Air Ventilation Seat Control Module LH, 2ND Seat Warmer Control, Module LH, 2ND Seat LH Reclining Folding Actuator
  • CLUSTER 7.5 A Instrument Cluster, Head-Up Display
  • MDPS 10 A MDPS (Motor Driven Power Steering) Unit
  • A/C 7.5 A E/R Junction Block (Blower FRT Relay, Blower RR Relay, PTC Heater 1/2 Relay), Front A/C Control Module, Rear A/C Control Module
  • CHILD LOCK 15 A ICM (Integrated Circuit Module) Relay Box (Child Lock/UnlockRelay)
  • DOOR LOCK 20 A Door Lock Relay, Door Unlock Relay, Tail Gate Relay, T/Turn Unlock Relay
  • SUNROOF 1 20 A Front Sunroof Controller
  • MODULE 11 10 A Rear Occupant Detection Sensor
  • P/WINDOW LH 25 A Driver Safety Power Window Module, Rear Safety Power Window Module LH
  • MODULE 3 7.5 A IBU (Integrated Body Control Unit)
  • MODULE 6 7.5 A Audio, A/V & Navigation Head Unit, Low DC-DC Converter (Audio/AMP), Front A/C Control Module, Electro Chromic Mirror, Center fascia Keyboard, Driver/Passenger Seat Warmer Switch, Driver/Passenger Seat Warmer LIN Switch, Driver IMS Control Module, Rear Power Window Switch LH/ RH, Front Air Ventilation Control Module, Front Seat Warmer Control Module,2ND Air Ventilation Seat ControlModule LH/RH,2ND Seat Warmer Control Module LH/RH
  • WASHER 15 A Multifunction Switch
  • RR SEAT (RH) 25 A 2ND Air Ventilation Seat Control Module RH, 2ND Seat Warmer Control, Module RH, 2ND Seat RH Reclining Folding Actuator
  • WIPER RR 15 A Rear Wiper Relay, Rear Wiper Motor
  • AMP 25 A Low DC-DC Converter (AMP) A
  • CC 7.5 A IBU (Integrated Body Control Unit), Low DC-DC Converter (Audio/AMP)
  • P/SEAT (PASS) 30 A Passenger Seat Manual Switch
  • P/SEAT (DRV) 30 A Driver IMS Control Module, Driver Seat Manual Switch
Engine Compartment Fuse Box
  • MDPS 80 A MDPS (Motor Driven Power Steering) Unit
  • COOLING FAN 80 A Cooling Fan Controller
  • EPB 60 A ESC (Electronic Stability Control) Module
  • B+2 50 A ICU Junction Block (IPS 8/IPS 10/IPS 11/IPS 12/IPS 13/IPS 14/IPS 15)
  • B+3 50 A ICU Junction Block (Fuse - P/WINDOW LH, RR SEAT (LH), P/SEAT (DRV), P/SEAT (PASS), MODULE 11)
  • B+4 50 A ICU Junction Block (Fuse - MODULE 8, S/HEATER (FRT), P/WINDOW RH, AMP, SUNROOF 1)
  • ESC 1 40 A ESC (Electronic Stability Control) Module
  • ESC 2 40 A ESC (Electronic Stability Control) Module PTC HEATER 1 50 A PTC Heater 1 Relay PTC HEATER 2 50 A PTC Heater 2 Relay
  • ECU 6 15 A ECM (Engine Control Module)
  • TCU 1 15 A TCM (Transmission Control Module)
  • TCU 3 15 A TCM (Transmission Control Module)
  • B+5 50 A ICU Junction Block (Fuse - DOOR LOCK, IBU (Integrated Body Control Unit) 1, IBU (Integrated Body Control Unit) 2, BRAKE SWITCH, CHILD LOCK, RR SEAT (RH), SUNROOF 2)
  • BLOWER FRT 1 40 A Blower FRT Relay
  • OIL PUMP 40 A Electric Oil Pump Inverter
  • REAR HEATED 40 A Rear Heated Relay
  • B+1 50 A ICU Junction Block (IPS 1/IPS 2/IPS 3/IPS 5/IPS 6/IPS 7, Long/Short Term Load Latch Relay)
  • BLOWER RR 1 40 A Blower RR Relay
  • 4WD 20 A 4WD ECM (Engine Control Module)
  • AMS 10 A Battery Sensor
  • H/LAMP HI 15 A H/Lamp HI Relay
  • IG2 40 A Start Relay, PCB Block (IG2 Relay)
  • INVERTER 30 A AC Inverter Unit
  • POWER TAIL GATE 30 A Power Tail Gate Module
  • TRAILER 30 A Trailer Connector
  • HEATED MIRROR 10 A Driver/Passenger Power Outside Mirror, Front A/C Control Module
  • BLOWER RR 2 10 A Rear A/C Control Module
  • WIPER FRT 2 10 A IBU (Integrated Body Control Unit)
  • BLOWER FRT 2 10 A Front A/C Control Module
  • WIPER FRT 1 30 A Wiper FRT Relay
  • B/ALARM HORN 15 A B/Alarm Horn Relay
  • FUEL PUMP 20 A Fuel Pump Relay
  • ACC 1 40 A ACC 1 Relay
  • ACC 2 40 A ACC 2 Relay
  • ECU 5 30 A Engine Control Relay
  • IG1 40 A IG1 Relay
  • A/C 10 A A/C Relay
  • HORN 15 A Horn Relay
  • POWER OUTLET 2 20 A Front Power Outlet
  • ACC 3 15 A Rear USB Charger, Luggage USB Charger, Driver/Passenger Seat Cushion USB Charger
  • ACC 4 10 A Front USB Charger, Rear USB Charger RH
  • ICU 10 A ICU Junction Block (Fuse - ACC)
  • SENSOR 1 10 A Fuel Pump Relay
  • SENSOR 4 15 A Canister Close Valve, Oxygen Sensor #1/#2/#3/#4
  • ESC 3 10 A Data Link Connector, ESC (Electronic Stability Control) Module
  • TCU 2 10 A TCM (Transmission Control Module), Transaxle Range Switch
  • SENSOR 6 10 A Electric Oil Pump Inverter
  • ECU 4 10 A ECM (Engine Control Module)
  • POWER OUTLET 1 20 A Luggage Power Outlet
  • POWER OUTLET 3 20 A Rear Power Outlet
  • SENSOR 5 10 A Oil Pump Solenoid
  • SENSOR 2 10 A A/C Relay, Purge Control Solenoid Valve, Oil Control Valve #1/#2/#3/#4 (Intake/Exhaust), Variable Intake Solenoid Valve #1/#2, Electronic Thermostat
  • SENSOR 3 20 A Cooling Fan Controller
  • ECU 1 20 A ECM (Engine Control Module)
  • ECU 2 20 A ECM (Engine Control Module)
  • ECU 3 20 A ECM (Engine Control Module)
  • IGN COIL 20 A Ignition Coil #1/#2/#3/#4/#5/#6
If everyone is thinking the same, then nobody is thinking.
I see the trailer connector 30A fuse. And I see where I might be able to tap into something that might have power for the AWD version on my 2WD Telluride to power a brake controller. The mystery to me is how the light wiring harness feeds the reverse lights on the hatch. I’ll try to keep digging.
I thought I deleted the portion of my post but auto save must have added it back. As I could not provide the pics from my phone and changed to laptop.
Hope I shed some light to a topic I just learned about. If I get a chance to look into the 7 pin. I'll keep you posted
If everyone is thinking the same, them nobody is thinking.
I have been reading many threads and multiple forums trying to find an answer to the lack of a 7 pin wire harness. I just spoke to my Kia dealer which installed my hitch after delivery on my S with the standard 4 pin harness. He contacted Kia for me and told me that Kia IS working on a 7 pin harness which will be available next year. He did also confirm it will be available for the 2020 so it must use the same harness that the 4 pin plugs into currently. Still not sure how that will work with a trailer brake controller, might still need to be wired into the cab or use the Curt wireless/Bluetooth set up. It would be great if someone else confirm this with their Kia dealer, would feel little better coming from multiple sources.
Interesting info. They need to increase that tongue weight rating to at least 500 lbs to make this a viable towing vehicle. If they do that, I'll take another look.
Check this out - just don't go with the OEM option and problem solved.
Looks like I might be replacing my OEM hitch with the Curt. And if Kia can get the 7 pin wire harness out to us, then I'm good to go.
Curt install sheet still says not to exceed the manufacturer's towing guidelines. Owner's manual says 351 lbs tongue weight. Exceeding that even with an aftermarket hitch may still void your warranty.
Thanks, yes, I saw your other post. This is something that needs to be resolved by Kia corporate - their owner's manual seems wrong or misleading at best - or they just don't understand it correctly. Even the owner's manual says that max trailer weight shouldn't be more than 10% of tongue weight - and the two numbers in the manual don't make sense. Wish we had more clarity on this topic - so we wouldn't have to speculate what they meant by those numbers in the manual... frame vs. oem hitch (tow package) etc.
This is nothing new, unfortunately. They have pulled the same bait and switch with the Sorento towing capacity over the years.
Our local dealer wants $500 and $291 for the hitch and 4-pin harness, respectively. I can do the Curt 13420 hitch for $275ish, which still seems pricey. I have used Curt hitches in the past on several vehicles - they are very nice units. I'd still have to get a harness. Does anyone have a dealer or online source to get the factory parts cheaper than what our local dealer is quoting?
Wholesalekiaparts.com had decent prices on OEM but you have to search by part #. There is an aftermarket harness now on etrailer.com.
Thanks! Their prices for the OEM parts are pretty good:
Hitch: S9F61-AU000 $288
Hitch cover: S9F61-AU060 $40.25
4-pin Wire harness: S9F67-AC000 $138.75
Almost $80 shipping to NC from GA though. Woof.
This is the way I'll be going instead to save some $:
Ebay Curt 13420 hitch for $279 (free ship and no tax)
Ebay Tekonsha 118784 harness for $41 (free ship and no tax) [this is the harness etrailer is selling for the Telluride]
Note the curt hitch requires a small cutout of the stock lower bumper cover rather than replacing it.
Simple but important question for you all: Anyone know which way the ball should be mounted on the Ball Mount? The diagram from the part is as shown below, which would imply mounting on the top with arch concaved downward, and this looks similar to the white Telluride Brochure in dealerships, but I saw a video from a Kia dealer showing the exact opposite, see below and thanks in advance.
It can go either way — what you want to do is put it so that your trailer sits level. On my Telluride, I put it the way shown in the photo with the boat, on my Sorento with the same trailer it goes the other way like in the diagram. The trailer sits level behind either car that way.
