@Twelvolt LED headlights installed!! As someone who is a complete novice at this stuff, that was pretty painless. No need to even change the o-rings or even lube them up. As previously stated by
@NCTelly and others, the driver’s side is MUCH easier just due to the amount of room you have compared to the passenger’s side. But honestly, the passenger’s side installation went a smidge quicker since I now knew what to do, it’s just my hands got a little beat up and said a few cuss words trying to get that bulb out. I kept the desiccant packets in the dust cover, hopefully that doesn’t create a heat issue or anything down the road. The beam pattern looks correct, I made sure to have the wiring pointing in the 6 position after locking in, although when I installed the passenger’s side, I wasn’t 100% sure I got it in right, but the light didn’t wiggle or pull out, so I am fairly confident it locked in correctly. I’ll definitely try and post some pics of the lights at night time sometime soon! I also changed out the license plate lights with LEDs as well. I’m not 100% sure I’ll be doing the other lights in that Lasfit Telluride YouTube video yet. If I do, I’ll probably just do the front turn signals and forget about the reverse lights, not sure I want to pull paneling apart and such.
