@Tellthemride ah good info, didn’t think they would make that sort of change. If anything I just wish they would add access doors on the hatch for the reverse bulbs like they do on Seltos (and maybe others - just have seen it there)
Hmm, I may have misread the LED tail lamps to imply tag & reverse lights as well. Will hold onto the LASFIT bulbs for a couple of weeks till I can check the bulbs in person.
So looking forward to that!
Just completed LED upgrades across all the lights on my S Trim and confirmed that it all functions without error codes and hyperflash.
tl;dr
a) LED Bulb Purchased + Cost
b) Ease of Installation
c) Installation Guide
d) My Personal Take
e) Before / After Image
1. Headlamps
View attachment 13006View attachment 13007
2. Front Turn Signal
3. Front Side Marker
4. License Plate
5. Backup / Reverse
6. Tail
7. Brake
8. Rear Marker
9. Rear Turn Signal
I've been told that I will need a convertor to change out my headlights on my Telluride S to LED. But it seems that you did not feel that is necessary??
From what I see in this post, he used a bulb with the built in canbus to prevent the hyperflash. The bulbs he used are good as I had them before I did a complete headlight housing swap to the SX led. That you would need any extra harness for with a resistor. But if you are just buying the bulbs like in the post you tagged, you do not need anything extra outside the bulbs.
tl;dr
d) My Personal Take
1. Headlamps
4. License Plate
5. Backup / Reverse
6. Tail
7. Brake
8. Rear Marker
9. Rear Turn Signal
Did you get any hyper blink on the side markers? I ordered similar but slightly more pricy LED and I got hyper blink..
"3rd brake light" is missing or mislabeled in the guide? (The horizontal bar, at the top of rear, that only lights when brake are depressed)
tl;dr
d) My Personal Take
1. Headlamps
4. License Plate
5. Backup / Reverse
6. Tail
7. Brake
8. Rear Marker
9. Rear Turn Signal
Thank you for this post! I changed our Telly’s headlights and very happy with the result. Your research and guide made it easy.
I also appreciate all the subsequent posts to help others like me. Cool forum!
I just ordered the suggested license plate and reverse bulbs. Might stop there for lighting…
FWIW I just got a 2022 SX Prestige and the only exterior bulbs that aren't LED are the white reverse lights and the license plate lights.
I ordered replacements from Diode Dynamics and they work with no issues.
Hey there. I’m looking for tutorials on how to install new reverse and license plate lights on my 2022. Was there a guide/video you followed? TIA
Edit: nvmd I’m an idiot 🤪
So tomorrow, the 20th, will be one month of ownership. I decided to upgrade the license plate and reverse bulbs to LED as many here have. I have a 22‘ AWD SXP NF/T in Gravity Grey/Black Napa which comes with about 99% LED lighting throughout the vehicle. Not sure why Kia skimped on $20-50 worth to complete the set. But anyhow, i used different LEDs from most of the forum and bought them together at my local Autozone for $50. Amazon had the license plate diodes for about $3 dollars less but didn’t have the reverse diodes and figured I was already going to Autozone so I bought both of them there. While it seems slightly less expensive Amazon orders have worked and probably just as well, I decided to go with bulbs that I put into my 16‘ Subaru Outback Limited 2.5i w/Eye Sight. Figured that I already dropped 55k in cash on a vehicle I might as well make sure that the LEDs were from a reputable brand with a warranty on the diodes.
Now the work was pretty simple after some research. License plate bulbs took basically no time and I think it was well worth the swap as it completes the nice crisp white headlight/fog lights of the SX. These lights are on at all times when the headlights are active so this was my most important light mod. Now, the reverse LED’s I am not sure if it was a great value in a swap. The swap I did at night and really didn’t take much effort. Initial thoughts is that the LED brake lights actually drown out the reverse lights anyway and was hard to tell if the new LEDs made a difference. When off the brakes it does seem brighter or more clear and crisp lighting which i think will help others visibly notice I am in reverse rather than me being able to see better. Could be the reverse camera or my brightness settings but doesn’t seem like it did much in terms of illumination. Now, I would have to say the the appearance of the reverse LEDs look way better and again completes the SX LED lighting. One final positive overall is that I believe these diodes are drawing less amp than the OEM bulbs. So far I have not received any hyper flash or errors. I don’t suspect I will since I have been running these diodes on my Outback for about 6 years with no issues.
I can’t for the life of me pop the lift gate handle open to swap out the reverse lights. Any tips?
Need to grasp and rotate the handle with your finger tips gripping on the top inside of the handle. It flaps open away from the front of the car. You can use utility gloves for extra grip, I was able to do it without them though.
2 attempts of squeezing with all my might (and gloves) to no avail. I’ll keep trying but man is my handle stubborn. I can’t imagine it’s any different on a 22. There is a small slot on mine that looks like screwdriver access but I don’t want to risk marring the plastic.
edit: I got it 😄 thanks!
Just bought the Lasfit LED headlight, reverse and plate lights. hopefully will look good.
Does anybody have any good sources for non-hyperflashing turn signal bulbs?
I used these and they are great. Obviously replace them with like colors, but the fronts are easy to replace, threats, I have an S, in have not messed with.
No Hyperflash? They blink normally?
FYI. I upgraded my front bulbs to these Lasfits for a total of 72watts (instead of 60watts) and they're fantastic:
Also, I decided to take the desiccant out (even though they fit with the bulb in...I was worried about having enough room in there for the fan to cool properly.
