Check all your fluid colors.should i be able to see a crush washer on the plug or is it recessed?...doesn't look like engine oil though and not from the right location...10/26/21 with 1700 miles on the car noticed the leak on the floor...10/27/21 jacked it up to look for the issue
Thanks...I already compared the engine oil...photo is above...coolant is pink and brake fluid is yellow...transmission is sealed I believe...no idea where to even find the fill pointCheck all your fluid colors.
First, check your motor oil texture and color (using oil from the dipstick).
If it doesn’t match, move on to your other fluids.
Brake fluid reservoir level. Also, compare the color.
Next, look at the coolant reservoir (where you add the antifreeze) for a color match.
Finally, check the color of your transmission fluid (from the dipstick).
If you have any doubt to the colors, put them all on a rag that is the same color as the one you showed us in the picture and compare.
One of those fluids should match.
Btw, you may also want to clean up your garage floor, and lay a clean old white sheet underneath to catch any new drips, if your testing above is inconclusive.
I like this plan. You can monitor it. And, when due for the oil change, mention it to the service people, if needed.have my wife checking under her car before she leaves work and i have been checking under it while in the garage...no more leaks thus far...not sure if i want to bring it to the dealer and have them start to tear it apart looking for a leak that all evidence was washed away by the storm...i plan to take a really good look when i do the first oil change...it's got a little over 1,700 miles now and the oil change intervals are 8k miles by the maintenance schedule...i'll probably do it around 7,500 miles
no...the dealer is also 25 miles away...i plan to do my own oil changes and tire rotations to save money...i may do the first oil change early just to get any metal flakes out of the engineI like this plan. You can monitor it. And, when due for the oil change, mention it to the service people, if needed.
As for as oil changes go, I use full synthetic, and for the first 3 changes, opted to do every 5K until I reach 15K (Currently, 9400 miles), then plan to go 7500 thereafter. I also do a tire rotation and have decided to add Techron after each oil change.
Did your dealership offer a complimentary oil change?
We added the rear bumper protector. We play a lot of golf and are always sliding our golf clubs in and out of the car. Also, I keep a pair of non-polarized sun glasses in the car as it's a little easier to read the HUD. Not a big deal but just a little easier to read the display.so i know no one wants to hear it but xmas is coming and i'm trying to get a head start on ideas...my wife also has a birthday the same month...any accessory ideas for her telluride?...she wears sunglasses all the time so i'm thinking i'll get her one of those clips that go on the visor that you put the sunglasses arms in and close it since her glasses don't fit in the sunglass holder
does anyone have any accessories that they really find useful...i'm not looking to buy anything huge unless i find it to be something she would def use
thanks...i'll have to check that out...all of my wife's sunglasses are non-polarized and i leave a cheap pair of my non-polarized sunglasses in the glasses holder cause hers don't fitWe added the rear bumper protector. We play a lot of golf and are always sliding our golf clubs in and out of the car. Also, I keep a pair of non-polarized sun glasses in the car as it's a little easier to read the HUD. Not a big deal but just a little easier to read the display.
2021 SXP in Wolf gray with NF. 3200 miles. Paid MSRP after 7-month wait for delivery. Sold 2014 Lexus RX350 on Carvana for $4K over KBB.
Congrats! Keep us updated if you run into any issues. Seems like a nice product and very simple to install.installed last night...working correctly thusfar...should be less annoying now
yes...in the video it looks like they used a roll of tape to hold up the trim...i skipped that step...i also did it without a flashlight for the extra challenge lol...i didn't even trim the zip tie, just pushed the tail down through the hole...wife is happy it works@Point37 Is the install as easy as the video makes it look?
